WDK Laydown pipe
DylanS
Gorilla Smasher
Lebanon Pa
Get a PFP
I was pretty sure the manifold bolt pattern wouldn’t fit gp800 cylinders but I could be wrong, does power factor produce a manifold for gp800 cylinders? I’ve heard of guys running the chamber on a WDK manifold but I’d still need his billet manifold. I’m broke too so there’s another reason lol.
if I remember correctly, the old WDK cast manifold is the one that the pfp chamber works with. the newer billet wdk manifolds are way too big at the coupler to work with anything, including the garbage wdk chambers. steer clear of all wdk junk if at all possible
DylanS
Gorilla Smasher
Lebanon Pa
Personally I’ve never had an issue with Jeff’s stuff and it’s affordable for me so I can’t complain. His dry pipes might have been a different story but the few wet pipes I’ve had from him have done me good. I guess I wouldn’t know because I’ve never tried a powerfactor chamber on my motor Lol. Maybe I will just pick up a power factor chamber and keep the old cast manifold, depends if I can find one that doesn’t blow my wallet in half
Appreciate the info though
DylanS
Gorilla Smasher
Lebanon Pa
My wet Wdk pipe cracked , never could find leak till I gave up on Wdk setup
Ski always ran like poop , never saw any exhaust under hood
That was the pipe and motor me and you could never make ends meet on!!! Lol. The setup is really hard to get dialed in for sure but I think I’m close.
DylanS
Gorilla Smasher
Lebanon Pa
if you are talking about the newest manifold that has the same length runners, no. I have the billet manifolds that bolt up to the billet 1200 blocks.
all WDK stamped chambers are the same.
Ok, I was looking for a the billet gp800 manifold and a stamped chamber, I have a welded one now. What condition? The manifolds should be interchangeable.
