Wdk rok
Visalia ca
•Full carbon waterdawg Kustomz rok hull fresh build from the ski clinic everything is new or rebuilt. Asking 12k obo
•Dasa 827cc 6mil stroker (power valve can be added)
•48mm dual black jacks
•dual cooling
•r&d intake manifold
•vforce 3 reeds
•msd enhancer
•Ada grittled head (220psi)
•144 mag pump
•factory B pipe
•factory pipe manifold
•big swirl skat track
•exscream trim
•rrp cast pole
•rrp steering
•glassed in footholds
•jet maniac mid shaft
•custom aluminum fuel tank
•epic industries scupper valve
•bilge pump with pjs bracket
•hot products bilge pump switch
•primer bulb with inset billet housing
•freeride innovations pissers
•billet bilge outlet
•all fittings and connections are brand new
•fuel lines/water lines brand new
•cold fusion fly wheel cover
•cold fusion drive shaft couplers
•steering/trim/throttle cable NEW
•billet eyelets (for tie downs)
•jet dynamics top loader
•carbon fiber ride plate
