Wear ring replacement
RoyalFlush@PCB
Shootin' The Crap
PCB
Is it possible to replace the stainless wear ring? I have a 140mm Mag wear ring with a cracked housing and was wondering if it was possible to remove it from the bad housing and re-install it in a good housing.
When sleeves are replaced in a cylinder, it is heated up and the sleeves can be removed and then replaced---is this possible with a wear ring?
tricky1
XXX
Alabama
The OEM ring has to be bored out as the aluminum is cast around it. It is not a big job, just takes time.
RoyalFlush@PCB
Shootin' The Crap
PCB
You got the tools? I'll send it to you. This is the same pump we discussed earlier this week---found out as soon as I took off the rideplate.
You in OB this weekend?
RoyalFlush@PCB
Shootin' The Crap
PCB
This thread is done, but don't shut it down Mods--- at least until Charlie and I are finished discussing the picture I posted! :pancake:
