Wet Pirpe Adjustment
I recently purchased a factory wet pipe for my SXR. I remember somebody posting a new product that would eliminate the smaller water adjustment screws and replace them with something better. Maybe some sort of T-Handle. I looked through all the new product releases and cannot find it. Does anybody remember the thread or product? Thanks for you help!
Waternut
Customizing addict
Macon, GA
It's in the for sale section but I believe those were primarily for the people with tuning screws that were seized. You shouldn't have to adjust that pipe constantly or even enough to warrant doing all that work. Usually takes about 10-15 minutes based on FP's recommendations and then if you're really anal, you could adjust the cooling once more each year to adjust for water temperature changes.
Tuscaloosa, AL
The are BK twisters. But honestly, put some antisieze one the screws or grease. About every 2 months, remove the headpipe and make sure the screws still turn. re lube as neccessary.
Thanks for the help guys! I will just put some antiseize on them for now. I ride about 99% in fresh water anyways so I shouldn't have too many problems!
