Thinking about installing foot holds in my SJ but seeing these build threads of having to remove all the oem foam looks like a nightmare. What are the odds that it can be dry in there or wet
You can always drill small holes (maybe 1/8 inch) in the rear of the hull just above the lowest points on each side. If it drains water you will know. You can plug these holes with a variety of products, or a couple stainless screws. I would use a white puddy I cannot recall the exact name of at the moment. Tec-mix?
