What Bars and risers for B1
INDebtSJ
Having a VISION!
Ga
I have searched but there is a lot of info that isn't clear on stock set ups and I do not want to have to re order.
Also are there bushings that can be replaced on the steering stem?
Thanks!
Mike W
Infidel
North Florida
I ran a 62t factory pipe manifold on a 61x cylinder in the past. The only difference I could see was the bolt holes were larger. Not sure if there is any difference in the exhaust ports between the two. If you call the Pro Tec tech line they are extremely helpful.
Were you able to find risers for your B1? I'm looking for some as well to use with 7/8" Blowsion bars.
INDebtSJ
Having a VISION!
Ga
I have a Protec stainless chamber one. Missing the mani.
Also have the b pipe set up but no b1 chamber.
Figured this would be cheaper
INDebtSJ
Having a VISION!
Ga
I am using risers for the fat bars.
