Super Jet What Factory Pipe is this?
icecoled007
Captain of this ship
Colorado
I thought I bought a mod pipe from a member on here....but maybe I am wrong. I saw another highly modified ski this weekend and I noticed his pipe had a big gap between the gas tank and the pipe, whereas mine sits right against the tank.
Is this a mod or limited pipe? :drillsergeant:
While were at it, why does my head pipe have ring worm? :pokey: Has anyone seen this before?
Lastly does my top screw look wide open or slightly open? I can screw it down anymore but I don't know if that's because of corrosion or if its supposed to not close as much as the others.
Australia
this is just a guess but looks the same as my ltd pipe mine is realy close to the tank.
my screw is almost closed with 3 threads showing on the adj screw.
and mine has ring worm too there just like that lol
Tuscaloosa, AL
you have a limited chamber. The only difference is the Mod chamber is about 1" - 1.5" shorter expansion chamber. You dont need a picture to prove that. Also, That chamber is just fine for your setup. Looks like you have a limited motor setup. That is what that pipe is designed for.
icecoled007
Colorado
Ya, I am happy. I have more of a limited setup.
That is the welded up port of where the sand from the casting core comes out. The head pipe is water jacketed so you would need a place for the sand to come out of, then just weld it shut or put in a "freezplug". BTW that is what freezplugs are for.
