i have a 96 sj, with factory b pipe, msd enhancer, ad racing head 32cc domes, 12/20 skat, should i stick with factory recomended premix ratio, or go with something else.
My set up is almost identicle to yours, minus the ADA head (I run stock w/stock compression). I mix at 40:1 and use Walmart oil (Super Tech, the cheap blue stuff). I ride A LOT, averaging 3-4 times a week and I am getting 4-5 years out of a motor, which translates into 1200 to 1300 hrs before I need to rebuild (using Walmart oil at a 40:1 mix).
I have pretty much same setup and year. I run 40:1 quicksilver, I ran penzoil for awhile but I found it leaves more oil residue. Quicksilver burns clean and smells good.
