Super Jet What should I do to turn this into a flat water freestyle jet ski?
I have installed a B pipe, MSD enhancer. It has a 62T case, and the compression is 175. I am planning on buying a lowered hood kit, possibly from WDK. I am also buying their footholds.
Sanoman
AbouttoKrash
NE Tenn
X2 on the WDK footholds! Unless you have tiny feet.l'm in the process of cutting the top of my (wdk) footholds out right now cause they were not big enough for my 9.5 feet to fit into! There wasn't enough room for turf and pad.What Mcdog suggested is correct
Waternut
Customizing addict
Macon, GA
Hood is mostly for looks. I recommend spending the hundreds of dollars on something that will give you punch. You've got a good start already but some other items will really put a smile on your face besides a new hood.
Footholds are first. A 9/15 hooker impeller from impros.com will really make a difference and I think should be second. A lightened flywheel and bored reduction nozzle will help with bottom end power. A proper high compression head with a girdle kit will prevent the cylinder from cracking and will most likely give you more power as well because the design is far superior over a milled stock head. You can buy an ADA girdled head , reduction nozzle ($59), and lightened flywheel ($105) from jetmaniac on this site. He's an awesome guy to deal with. A lot of people like the Tom21 footholds and are they are decently priced and much better than WDK footholds. He's on this site and I don't think he has a website. Here is the link to jetmaniac's master part list... http://www.x-h2o.com/threads/85372-...-Used-Yamaha-and-Custom-Build-Parts&highlight=
Those items above will give you all you will need to really get into the sport. All of the items I recommended will cost only slightly more than a nice hood. Once you get comfortable with that setup, you can decide what direction you want to go after that. Whether it's a lightweight hull, bigger engine, or whatever. Lastly, WDK has "a reputation" and I think should look into before you buy anything from him and decide for yourself if you want to deal with him or not.
