- Hutchinson ks
OK where are all the superjet gurus? I'm having a problem that i can't solve to save my life. I guess I'll start from the beginning. Bought an empty 2006 sj hull and started gathering parts. Motor is a 62t bottom on 61x topend. Dual 44s. After I got it put together and took it out it ran perfect for about 10 mins then bogged really bad the more I rode it the worse it got. I thought it was getting water in the motor so I took off the exhaust and noticed a gasket on my pipe (Coffman sizzler at the time) was leaking. Replaced it and took it out ran perfect...for about ten mins... So I replaced gasket after gasket thinking it was leaking water... So after about 6 gaskets I said screw it and bought a new pipe (r&d wet pipe) took it out same thing. So at this point I knew I wasn't chasing the right problem. Did a little research and some people having the same issue had bad stators. So yesterday I replaced the stator with one I had on my shelf. Took it out today. And samething. I even drove home grabbed an extra cdi I had and replaced it. Still does the same thing. I'm lost. If i let it set over night it runs fine till 10mins has to be engine temperature related??? I already removed temp sensor from ebox Anyone have any idea??? This thing is driving me absolutely crazy..
