- Jacksonville, FL
I have searched and searched and don’t know what to do first. I want to get more down low. See below for my setup.
I am not going to change the jug (I already know that it is not the best for what I want, but it is what I have to work with). I think I want to get a stock stroke lamey down the road. Saving up and working to get better first. With that being said what are the things I can change that would bring the power down low? I am looking for changes now that would also work for my new cylinder down the road when my skills are better. This thing has to much top end for what I do (flat water freestyle and surf) so losing top speed is not a problem.
I just got my jetting worked out and that helped a lot.
I have a Rad flywheel I am going to put on for starters. That should help?
Would a bigger nozzle help? I am looking at a pro-tech to buy. Not sure of the size but bigger than stock.
Would a different pitch on the prop help?
Engine 62T Cases
64X Jug (OEM) 85 mm weisco
Carb OEM 38's prok arrestors
exhaust B-Pipe front and rear exhaust
Prop Solas YB-SC-J 18.5 14.7
ride plate Riva Yamaha
intake grate Jet Dynamics
Engine 62T Cases
