What to do with overheat sensor wires
B-Roy
Makin' a Comeback!
MICHIGAN
My ADA head is on its way, and Im just wondering if I can just cut the wires off flush at the box?
Or should I leave them an inch long or so, and cap/seal the open wires.
douglee25
m3booooy
South Jersey
Open up the Ebox and unplug the sensor. Wrap the ends inside the Ebox with electrical tape and reassemble. If for some reason you go back to a stock head to sell, you'll be able to do such.
Doug
B-Roy
Makin' a Comeback!
MICHIGAN
I went for the "clean look" with my turf, and countersunk my bolts.
So I dont feel like rdoing my turf, so is cutting it alright?
douglee25
m3booooy
South Jersey
Hmmm. Can you just drill out the turf over the bolts? Honestly, I would think you're going to need access to the Ebox aside from the overheat sensor. No? If you don't feel like doing it that way, cut it, and shrink wrap each end separately.
Doug
