Freestyle what trim levers are you guys using?
looking to find a bmx lever or something that will give me more thow on my trim... i modified a lever off my bmx bike from when i was a kid. it was from way back in 1988 or something.. i was trying to heat up the lever and bend it out some more and it cracked.. so im looking to find something else that will give me max throw. i have a wammer trim system and all the levers i tried dont give me all the degrees.. iv seen levers on pros skis that are almost straight out from the handel bar when there not pulled.. i know their definatly modified something? looking for ideas? thanks guys...
iptamenos
Flipping Around !!!
Greece
i had used bmx levers in the past on some superjet's odysseys and some tech69(made in Usa very old product) this levers work fine in the bmx. but after some time on superjet become tidy but still working without problem (was the salt) if you don't try to adjust the lever up or down you don't have problem otherwise the bolt was cut ..
try this : http://www.danscomp.com
