What's a used Zieman single ski trailer worth
I'm not sure about value, it's really based on it's current asking price and condition. While it looks good what is the condition of the wheel bearings, the tires and electrical? If you do buy it either do away with that jack and replace it with one that bolts on the side where it can be swiveled up and out of the way or at the very least rotate the one on it to get that handle away from your vehicle. I've seen those do some nasty damage from cutting turns in reverse. You forget the handle is up some, carve a sharp turn backing up and next thing you know after you get out, there's a nice handle dent and paint gouge run across your tailgate. I've even seen tailgates get dropped on them because of absent mindedness...we want to get out on the water, we're at the ramp and we drop the tailgate instinctively...then it lands on the jack. I've never been a fan of those inner frame fixed mount jacks. That coupler looks like it's proprietary too, if you ever have to change it you might only be able to get it from them and it looks like it might be spendy. Or it might not be available at all if the company went under then you're into custom fab work. Trailer companies come and go all the time. Just a few things to consider :)
Stockton
Depending on model and condition or custom set up
$450/500 for single
$750 & up for double
You could start high and see if any interest & have room to get talked down some.
My small double was 450 and my large double was 700, both Zeiman but 10 years ago. I think I got 700 for a single like your but not a zeiman about 5 years ago.
SUPERJET-113
GASKETS FOR CHAMP BRAP!
Yeah that one you have looks really mint. You might be able to get $600-700+ for it maybe. The prices have really gone up around here, but what hasnt? I see Zeiman doubles going for $12-$1700 around here.
Is that double Zeiman that you still have the one I sold you? I have another double Zeiman yellow trailer if you're interested..lol Even has a hitch on it in case you want to pull another trailer behind it. hahaa
