What's the right pitch?
Hey guys, I have an eme micro fr hull. I have all 2014 superjet guts : motor, electronics, pump. In your opinion what's the best brand prop and pitch of the prop would give my optimal torque, while working we'll with my motor and hull.
Thanks a lot for any help
umm. that's a loaded question. so many variables. but if everything's stock i'd say hooker 9/15 for the most bottom end torque. BUT to get the best results, you will have to try a couple different impeller sizes.
Fro Diesel
creative control
Kzoo
Skat 13/18 big hub
Too many variables with a hooker. Out of the box people have measured drastically different pitches on hookers labeled the same.
I thought i could just pick a prop and go, but i have found like a motor a pump need to be properly tuned. Trying more than one can be a huge advantage to get the most out of you ski.
Tuscaloosa, AL
If you had a SJ, then I would say a Hooker 9/15 or Skat 13/17. But with it being a light small hull. May want to go up a pitch to a 10-16 Hooker or Skat 14/18. This is an unknown.
