Freestyle Whats up whitey??
JetManiac
Stoked
Vendor Account
orlando
What is up with the white background?
Is this a permenent change?
I have to select text and change color to read parts of older pms now.
We're having some issues with colors on themes. I got my best guy on this, so stand by.
JetManiac
Stoked
Vendor Account
orlando
If you highlight text in pms and then go up to color choices and select black, then you can read it again.
GSXR RACER MIKE
20 years of stand up
A couple days ago every time I went to post I couldn't even see the default text color the forum was choosing for me, I changed the text to white because I was using the black background. On a motorcycle forum where I'm a Moderator we use what appears to be a similar bulletin board, but on there the software automatically converts white text to black if someone is using a white background.
Cannibal
Tasty Human
Summit Lake, WA
This forum does too, but that's the main issue with the Darkness. I started having this invisible text issue months ago on my work computer. I switched to "boring blue" and haven't had the issue since. However, when someone tells the forum to make their text white, I can't see chit.
I talked to Mr Jett about it and he said that the Darkness theme is no longer supported. Maybe there are other themes that can be chosen, but I'm betting the Darkness is gone for good.
LOL... I couldn't see a reply from Jetmaniac on some parts I needed... geez.
The black should be still available.. html code is html code.
