FX-1 Where can i order bearing for the 140 pump swap?
Ive ordered a new shaft, pump, prop, x2 nozzle, and grate for the 650 pump swap and the only thing i still need should be the bearings. I can find the dimensions from another thread im just not sure where people are getting the bearing from. If anyone could help me out that would be great, i need to order soon since spring break is on its way!
I seen them on Ebay, same size like 750 pump
For the midshaft housing? im referring to the bearings that will fit in the housing and have the correct diameter for the zxi shaft
These are the parts im referring to:
(1) 20x52x15 bearing (fits yamaha housing and kawi shaft), (2) 20x52x7 seals
Also im unsure as to how the bearing and seals are installed (as well as the removal)
Hmm i cant seem to find a distributer for the seals. The only one ive found that i can actually buy is the ebay one and im not sure if its stainless. Anyone know where i can find some?
edit: nevermind, i got in contact with the company selling the ones on ebay and they have stainless available for $2 more each
So i checked out ebay and im fairly certain i found the correct bearing im just not sure about the seals now
This is the bearing i was looking at ordering, im not sure if its SS or not
http://cgi.ebay.com/6304-2RS-Qualit...ltDomain_0&hash=item563a2459c8#ht_2752wt_1141
Is this the right type of seal?
http://cgi.ebay.com/20X52X7-Metric-...aultDomain_0&hash=item3cb52c30a9#ht_500wt_922
just got the 2 seals and bearing in the mail from the ebay links. Ordered my seals with the stainless seal.
Damn good quality in IMO.
Are 2 seals needed or just one?
at least 2. I have read 1 per side but it looks like i can fit 2 per side so i might do that. I havent had a chance to try fitting two but i should be able to tomorrow when i go home from school for the weekend. Ill let you know if i can fit 2 per side as it seems like it cant hurt to have extra protection against leaks
Here is the contact information i have for the place i bought my seals from. It was an ebay seller but i emailed them about the SS and they just sent me an invoice so i cant recall which ebay seller it was but im sure if you just shoot them an email they can send you an invoice as well. I ordered 3 so i would have one extra but ordering 4 and using 2 on each seems to be a wise choice. Ill try to update this later tonight and let you know for sure if 2 will fit on each side of the bearing. Im headed home from school in a little bit so i can check after i get home.
Merchant
Ultimate Industrial Solutions LLC
17 HAMILL AVE
BLOOMINGTON, MD 21523
United States
sales@ultimateindustrial.com
301-560-1866
Description Unit price Qty Amount
-20 x 52 x 07 ADL SS - Metric Dbl-Lip Oil Seal with SS Spring $6.73 3 $20.19
update: 2 will fit on each side of the bearing so i would order 4
