- South Africa
I am looking to buy an AM engine for my Carbon Gen2 X-2. It has been shortened, 79" tip to tip, 71" bottom hull, intake increased to 160mm and running a 146mm SB Mag at the moment. RTR weight 305lbs with 8 litres of fuel in it
I recently moved to a city that is at 5000ft asl which causes a 15% power loss(I have increased compression but will not get all the power back). I want to run 95oct(our pumpgas, I think it is equal to US 93oct).
I want a balance between power and longevity, I don't want to be replacing stuff every 50 hrs if possible. I have to travel at least an hour each way to go ride so there must be enough power to backflip and roll easily on flatwater as I will be lucky to ride every second weekend. I am not against fitting Yamaha or Polaris based engines in if it will give more power for the same cc's than a Kawi.
Which is the right engine and from who? EME, Thrust, Xmetal, TC?
