Which prop for my SJ?
98 Superjet
83 mm bore
b pipe
JPC ported cylinder
ADA head 35cc domes
46mm BlackJacks
Riva filters
5mm Pro Tec stroker
TBM pump cone
MSD enhancer
Shredmaster
V force reeds
Currently I have a 12/17 swirl on it. I am looking for a bit more top end. Should I switch props? If so what do I need?
Thanks
98 Superjet
83 mm bore
b pipe
JPC ported cylinder
ADA head 35cc domes
46mm BlackJacks
Riva filters
5mm Pro Tec stroker
TBM pump cone
MSD enhancer
Shredmaster
V force reeds
Thanks
what do you think your top end is now i have close to the same set up and my top end is crazy.. i want more hit. did you think the cone helped you that much? i did not. is your nozle cut/ bored ?:mischievous:
Crab
thanks darin...noswad!
Seattle
98 Superjet
83 mm bore
b pipe
JPC ported cylinder
ADA head 35cc domes
46mm BlackJacks
Riva filters
5mm Pro Tec stroker
TBM pump cone
MSD enhancer
Shredmaster
V force reeds
Thanks
If you want top end get the Solas X prop, that sob had me doing close to 60 on my limited before I slowed it down by changing the pitch to about 12/15. Its still doing near 50, same hub as the swirl with straight cut blades.
yamanube
This Is The Way
Staff member
Mandalor
If you want to go fast get a dry pipe!
Also a 14/18 concord would work great...I even have one if you are interested.
I had a speedwerx dry pipe. It did not fit all that well. The b is so much easier to work around or install. I might consider a trade for my b for a Type 4 or 9 dry pipe? I have heard alot about the Solas X props.
