Which RN hull yr is the best for freestyle?
tightithrash
Zack Bright. I Thrash.
Oceanside, CA
from 96- 07 is the same exact thing. nothing changed.
from 08- present it is a smidge wider and the pump sticks out an extra 2 in.
go with a pre 08.
SJBrit
Extraordinary Alien
Bradenton, FL
In your other thread you are talking about building a motor, so you might want to consider a squarenose too if you are looking for a bargain. They have the exact same hull as a roundnose but the deck is different. I would personally go for a round, but a square is a great option that you can pick up cheap.
CUKE
BIGGER..STRONGER..FASTER
MIAMI
thanks I want a RN
snowxr
V watch your daughters V
Waterford, MI
Early RN hulls have proven themselves. The later black hulls seem to crack the easiest. It could be as simple as Yam changing the SMC mix a little over the years.
