- Rochester, NY
Hi,
Tore into my carbs, and can't figure out what spring was in there. Please check out the pic and let me know if you can tell what it is. Pop-off tester won't be here for a few more days...
2 springs on left came in a genuine Mikuni SBN 38/44 rebuild kit (what are they?) and the 1 on the right is what was in my carbs. I'm thinking that the stock 115g was in there all along, instead of a 95g, due to the mistake on Factory Pipe's instructions...
Also, N&S were worn, and replacement 1.5's are on the way. With prok's, 180psi (35cc domes), EPIC cdi running waxhead's curve, b-pipe, stock 38's w/ 75/135, should I still be looking for a pop-off of about 45-50psi? Or, should I go a bit lower?
Thanks!
Thanks!
