Other Which waterboxs fit in a brawler?
Looking to get a quieter waterbox for my brawler, which relitivily quiet waterboxs will fit the hull.
I have a TDR box now and I cant stand it, its so loud it gives me a headache
X Metal as loud or louder to my ears than a standard TDR. Power Sprays tend to be louder. OP, do you have a Power Spray model? Does it have a water inlet at the exhaust inlet? Sometimes guys have this and plug it instead of putting water to it and it can be obnoxious. What pipe/stinger setup? Have you restricted the water to the stinger and really dried the pipe out? If you have cut the amount of water to the water box you're gonna have a loud ski regardless of setup. Try giving it more water at the stinger. I've run 4 TDR's without issue of noise, one on a stroked/bored P/V motor. JetFiend is using one with a Type 4 dry pipe on a stroked/big bore DASA in a short hull without issue. I only bring these up for example, maybe there is something you can do differently to utilize the parts you have in setup as opposed to buying another part.
I do not have the power spray model, I have tried adding more water flow to the pipe stinger, still very load, I may try and add water injection somewhere on the waterbox, whats the best place on the waterbox to add a water fitting? Thanks
Its so loud now I really dont even want to ride it, It hurts my ears and Im sure everyone else at the lake is pissed at me
That's odd, never had that experience. When I've told people before that I was a running a TDR they were always surprised cuz the internet says they are loud. You got any pics, maybe see anything. I'll pm you my number.
Jp79
Building Brawlers
Harveys Lake,Pa
ATP and H2O design fit nice in the nose and are much quieter than that box is. Ditch the TRD and switch to one of those allowing you to.position the box in the proper spot and then you can run either a silicone tube to the bulk head of an alumin section of straight pipe.
