Custom/Hybrid white sasquatch Rok-R build
burton391
in your house
WA
Just like the white unicorn the white sasquatch is scared easly and is seldom seen!
But hey lets give it a try.
picked up my full carbon infused Rok-R at the end of Surf Slam. Not a 100% sure on every detail of the build so we will just have to take it as it comes.
pics from the day i got it.
a few more.
add a few more!
burton391
in your house
WA
Maxx 144 set back going in the build unless it sells.
65U nozzle, removed some weight and bored it to 85.25mm to start.
nice improvement over last season.
burton391
in your house
WA
pump istalled with thrust trim. dual quick release fittings. pro tec steering nozzle.
The ride plate that is included with the hull. would like to keep it this length to try in the surf. will see how it goes.
Going to try this shoter RN plate first.
not to bad.
burton391
in your house
WA
Nice! What power plant do you plan to use? Are there inserts for a scoop-grate, or do you just not run one?
going to run a 701 this coming season. i machined a spacer to fill in the gap of where the intake grate would mount. it follows the curves of the pump shoe.
swapmeet
Brotastic
Arlington TX
Wonder if those quick disco's would work on a SJ. Pretty cool.
Be careful with that short plate. This is the reason the flow guard was built I believe...
Fun build, i'd love to try this out. Did you weigh the hull before you did all of this?
burton391
in your house
WA
the weight came in at 67#. hull, intake fin, all inserts, hood, hood gasket, hood breather tubes, front pin latch system, foot holds,versi plugs, tank and battery pods, pole bracket, and motor mounts.
burton391
in your house
WA
CF goodness
Installed my Titian pole with WDK pole bracket and rrp pole bolt. very pleased with how it came out.
burton391
in your house
WA
Thought i would do an inspection on my 701 going into the boat and got some news i did not really want, but better now then later i guess.
