- Midland, Ontario, Canada
Who’s running a stiff KP pole setup with an RRP bracket? And what are you using to accomplish this ? Does the RRP Spacer for in the base of the pole fit properly or is there something else being used?
I run rrp cast with no spacer and the pole tight. I flip and roll qith absolutely no footholds. Tight pole ia the best way to ride. Makes it like mx/bmx
