300/440/550 who has made a custom ride plate??
kawasaki168
kawasaki168
i want to know diretions on how to make an extended rideplate for my 650sx!!! i want one as long as a dominator rideplate that they have for the 800's! the stick out about 7 inches! thats wut i want. now how the hell do u make them?!?!???
'Crockett
Freelance Smartass
Be careful about adding too much length . . . . . . .
We added 4" to a 550 plate once, it eliminated about 75% of it's unwanted porpoising. . . . . . . . . . it also eliminated about 75% of it's ability to turn too !
You'll need to be able to do some Heli-arc welding, get two plates that are the same style and cut one off square. Then add a piece of the other one on to it.
gorilla
There's Always A Light At The End Of The Tunnel !!
Lost Wages NV
put some head washers in-between the ride plate and hull.
that a cheap way of getting the nose down.
i also put a pump wedge on the 93 650sx i had, and it help'd BIG TIME.
welding just a piece of metal to the back of any ride plate will help too.
i was going to put some 750 sxi stock rear sponsons on that 650sx, but sold it before i could test that way.
good luck
gorilla
kawasaki168
kawasaki168
You'll need to be able to do some Heli-arc welding, get two plates that are the same style and cut one off square. Then add a piece of the other one on to it.[/QUOTE]
wut u mean by heli-arc welding?
W
wydopen
Guest
if you want to do any freestyle i wouldnt extend your plate
Waste Land
Non Multa Sed Multum
Florence, AL
wut u mean by heli-arc welding?[/QUOTE]
If your asking. IT's not gonna happen in your garage unless you wanna pay the $.
gorilla
Lost Wages NV
mig or stick welding will work, but tig (heli-arc) is the cleanest and strongest weld.
any good machine shop should have a tig welder.
i paid $35 to have a sj rend ride plate welded.
i made it 4 inch's longer.
it helped a lot with the shooting for the moon from the beach (start) issue with my fat a$$ on it.
good luck
gorilla
Crab
thanks darin...noswad!
Seattle
good luck
gorilla
And my brother Gasgas owns it now!
gorilla
Lost Wages NV
crab, that ride plate will work killer on your rn, if you are going to race it.
that's a $100 ride plate after all the $$$'s i had to put into it.
good luck
gorilla
upstand2
upstand2
N. IL.
Well I'll get lots of Negetives about this I'm sure. I just bolted a piece of fiberglassed re-enforced plywood on top of the rideplate with two strips of 1/4 steel. It worked GREAT. I think the guy who started the thread lives by me. If you ever launch at Winthrop Harbor IL. , PM me you can have it to try or to model yours after. Mine was 5" extended and really helped stop the 650 from porposing , did'nt hurt jumping one bit. Never broke with lots of fall waves last year too.
