jetskee
Team Not-As-Ugly-Anymore
- Newark, Ohio
Hey, guys, long time no post.
Here's the deal....
Ski ran fine at the end of last season. Winterized it, tucked it away in
the basement, no problems.
I got it out yesterday for the first time, put some gas in, fired it up, and
it revs up just like I have the throttle pegged. I thought "Weird...maybe it's
just burning off all the WD-40 I shot in it at the end of last season?".
So I took it to the lake anyway, and once it was in the water, it seemed OK, even though the idle was very high and I had the idle adjustment all the
way out. So it's still not normal, but I rode for an hour, no real
problems.
Took it out of the water, started it on the trailer, and IMMEDIATELY it revs to full throttle. So, I'm kinda stumped.
What I've checked so far:
- Throttle is working fine, cable is not stuck, the plate in the carb
closes like it should. The spring that holds the plate shut is strong....
even when it pegs at full throttle, it is not sucking open which is what
I thought might be happening.
- Changed spark plugs, just for the heck of it, same problem.
So, does this indicate a gasket leak somewhere? It has to be pulling air
from somewhere, if it isn't coming through the carb. Can it really suck that
much air to rev that high due to a gasket leak?
Any help is appreciated. Thanks.
Here's the deal....
problems.
