SX/SXi/SXi Pro will a 650 pipe fit on a 750?
I have been kickng this around on my freestyle setup 750sx. I was talking with Tim at Zforce and he said a 650sx pipe with mani would work great for freestyle. Im thinking about going with a new 650sx factory pipe with aftermarket mani. He said that you would have to use a U-bent pipe. Does anybody have any pics of this setup?
My main concern would be running it over to the other side of the hull. I guess the waterbox would be deleted and maybe a stinger would be added on that side?
Can anybody help a brother out? If not i will save my $$$ and get a limited factory pipe.
The way Ive seen it installed was the pipe came straight up the left side, through the U bend and then back under the pipe and back into the waterbox. I remember reading about this before and thought the gains were better on the topside and not the lows but I wouldnt argue with Tim. He knows his stuff way better than me lol. Just my .02
bent pipe
i dont have a pick of the piping but when i first got my 750 it has a 650 westcoast exhaust so i sold that got a factory pipe and went the right way. since the water box is on the exhuast side the 650 pipes usually just go straight to the nose of the hull so its just a piece of aluminum pipe bent in a "U" shape and then some exahust hose to connect it to the water box. just go to a local muffler shop cut out the bent on some paper as you match it up to your pipe and motor then have them bend that or a couple pieces if its cheap enough.
