will a 700 wave venture pump and motor work in a RN
Dubs chops
livintit dot com
I know the motor will work, what all will I need that wont swap over to my 2004 SJ? I appreciate all the help.
would I be better off just shopping for a waveblaster instead?
JetManiac
Stoked
Vendor Account
orlando
You need to be more specific, do you mean a from a waveventure 700?
Dubs chops
livintit dot com
sorry 400 was a typo. yes a 700 wave venture.
i need a donor with a pump and motor i can use for my RN hull.
bored&stroked
Urban redneck
AZ
My buddy put the whole driveline from a vxr 700 in his roundnose, oem sitdown impellor , stock single carb 61x and all, and the thing freaking hauls ass. Seriously made me wonder what I was doing wrong with my ski.
JetManiac
Stoked
Vendor Account
orlando
The driveshaft and midshaft from a Pro vxr 700 do not work in a SJ, so he must have changed those. Just do not want others to think they are the same lengths and compatible as is.
CRJ
Hibernating
Toronto
Motor and electronics, yep!
Pump stator, yep!
Pump prop, yep!
driveshaft, nope!
Wear ring, nope!
Nozzel, dont think so, been a while since i was under a venture. :D
Decent donor though, gets you pretty much everything.
I have used the sitdown wear rings by using a flat 1/2 bit to counterbore the side against seal and putting the bolts in backwards. Did it many times without issues. Use a socket on the counterbored side to hold bolt head and tighten the nuts on the outlet side. Save some $$.
