Mouthfulloflake
ISJWTA member #2
- NW Arkansas
at the bottom of the Exh side of the bottom sleeve on the Mag end cylinder...SuperJETT said:Where is the chip?
Mile9c1 said:No problem.
Mouthfulloflake said:so I dont need to smooth it, or chamfer or anything?
just leave it like it is?
I plan to sawzall out the exhaust ports, and then send it off to be bored.
romack991 said::bigeyes: :bigeyes: :bigeyes:
I hope your kidding about using the sawzall!
sflsurfrider said:make sure there isnt a hairline crack, in the sleve, going up from the chip. they can be hard to see till after a hone or bore.
youll be fine with taking a rasp or a sawzall and smoothing out then chamfering.
sflsurfrider said:dude, you dont use a sawzall to fix your chipped sleeve. im not sure where you learned pwc mechanics, but anybody that knows anything about engines in general knows that a sawzall is only used to deck a cylinder.
Mouthfulloflake said:no way man, decking requires VERY precision work.
I only use a belt sander for that type of work.
