will this transplant work???
just bought two sn sj with trailer 90 and 94 one is a parts ski the other is all together but motor locked solid i have a 95 wave raider with the 701 i believe is this a simple swap of motors will the ebox match up and everything else... and will the coffman pipe and exh mani fit on the 701??
Engine Transplant should be easy and no problems, coffmans you will have to dremel/open the manifold to i think 43mm arround 47-48mm if i can recall, also do the same with the exhaust manifold gasket otherwise there will be a lip, carburator needs to be rejetted and you are set !
You should just unplug the 650 ebox from the start/stop switch and battery and pull it out with the bad engine and swap in the 701 raider motor and ebox in its place. All wire lengths should be fine ( ground, hot wire to battery and starter... etc ). If not swap out longer leads from 650 ebox cables. If you think there is a bad component on the 701 ebox let me know what gave you the idea it was bad and i can help you troubleshoot.
