That would be killer. When I bough the set up it came with an set of faded instructions that were contradictory and i don’t want to fry anything... Waiting for ATP to respond as well. If you could I would be thankful!
I used atps instructions for a oem box install. I decided to install mine in a IP67 lexan box with matching fittings and used both ATP and Yamaha diagrams
Love mine! ATP will hook you up as well. Great product. I think I'm the third owner of mine and (after a little love with the connections) it's been flawless for 2 years.
Static is set at 50* on the stator. Really easy to setup doesn't even have to be in the ski. I can send you the curves I have, one I received from a user and the other I made that had a bit more timing
