Woodruff key
Just pulled flywheel, it's the key supposed to be off center??
Sent from my C6725 using Tapatalk
that doesnt look original to me. it was likely custom made by someone looking to gain a 1-2* timing advance by moving(rotating) the flywheel slightly on the snout of crank. same idea as moving the flywheel pickup with the r&d timing advance piece.
Pablo
sqeez bth levrs & lean bk
georgia
I have a key that looks the same. Took it out and haven't used it. My assumption was a loose FW nearly shearing it in half. The key isn't there to hold it in place anyway but I like the assurance if the snout bolt ever did loosen up.
I had a woodruff key break and stick back together like that after my ski idled in reverse.. Yes that is correct lol
