- Kennesaw GA
Wanted to trade built Square Nose SJ for SXR. For trade only, im not looking to sale my ski at this point
Ski rips hard and is water ready with current GA registration
-1990 SN hull with footholds, reinforced bondline and pole mount area
-UMI -2" aluminum pole, Blowsion aluminum pole bracket, UMI steering
-727cc 701 based motor. LPW ported 61x cyls with 82.5 mm pistons, ported 62t cases with low hour oem crank, motor was rebuilt a few seasons ago and has very low hours. Oem duel 38mm carbs, couch motor mounts.
-ADA girdled head with 35cc pump gas domes.
-"Factory Pipe" limited B-pipe, LPW ported manifold and headpipe, all 3 screws turn freely
-"Factory Pipe" aluminum waterbox
-MSD enhancer with lightned flywheel
-144mm pump with "Hooker" 9-15 impeller, ocean pro reduction nozzle
-Worx 205 scoop intake grate
-Worx ride plate
-Dual cooling, pole limitied rope, dual bilge pumps
-Im sure theres more that I cant think of right now
-Worx ride plate
