x-2 750 what impeller
Shanex-2
funtion before style
Clearwater fl
I don't know if wave jumping can fit in the freestyle or freeride subject but probably are similar qualitys. my question is what would be a good impeller for an X-2 with the 95ss small pin 750 with a westcoast head with 28cc domes (180 psi) dual 44 carbs and a coffman pipe 750 elecs? What is a good pitch to use ? Should I go with SOLAS or SKATTRAK ? swirl ? standard ? concord? :feedback: ect. ect. ?
Crab
thanks darin...noswad!
Seattle
Stock sxr with stock X2 nozzle will hit hard.
Shanex-2
Clearwater fl
THANKS FOR THE INFO! will I need to have it cut back I have the 650 pump housing still ? should I considder switching to the 750 housing ?
