X-2 Lever actuated trim ideas pleezze ?
Seeing as all the hard stuff (trim nozzle/trim cable) has already been done at the factory, it strikes me that some sort of (hand) lever and cable connected to the existing position selector would be the way to go.
I just set mine up with up trim for freestyle on a lever if you still need info
I used a clutch lever from a atv and a throttle cable from a Yamaha wave venture and my ski already had a tube in the right side and I flipped the trim nozel over and ground it out so it has more movement and made a bracket for the cable to pull against or mount to it's pritty simple
mike b
California
My buddy used the cats trim cable and lever off a yamaha onto his. He has it set up for positive and negative trim I believe
That could work too but I don't think you would get as much movement up I'm going to eventually try to flat water flip mine once I get the 1100 motor in and 148 pump so I set it up for as much up trim as possible
