x2 motor carnage?
So i took the x2 out on the lake today. While taking a right turn and giving it throttle i hear a weird noise and feel power lose. so i idle the ski back into shore. The motor wasn't sizzling water and didn't feel very hot. I started the ski after a few minutes and the ski continued to sound not normal. so i took the ski home and took the head off. The front cylinder's piston has pitting along with the front dome
. The rear cylinder look fine and i was running the ski on the rich side. What do you think the happened to the motor to do this. I was running the westcoast head with ep7029 domes with o rings and westcoast head gasket. The list of motor modes are listed below
Motor- single cooling. Running Red line race synthetic oil-32/1
westcoast pipe and head pipe
westcoast waterbox
westcoast head
42mm keihin cdk2-Kn&n(jets-160/85)
motor bored with .50 pistons
new cdi with jss wires and msd boots
fmf cages with after market reeds.
jet flow valve
dfw
. The rear cylinder look fine and i was running the ski on the rich side. What do you think the happened to the motor to do this. I was running the westcoast head with ep7028 domes with o rings and westcoast head gasket. The list of motor modes are listed below
westcoast waterbox
westcoast head
jet flow valve
Looks like a bearing retainer came apart.
