JMSoc02
Cheers To The Water
Sup, I just got an '88 X2. Runs good, but I seem to be having a problem with water. I keep getting loads of water into my hull, especially when i sub it. I looked at the hood and the scoop looks aas if it directs the water right into the hull (assuming for air to go in not water). I was thinking about closeing it up or covering it some how, but i didnt know how much air movement you need into the hull. Also I have a '91 VXR that I was thinking about an engine swat to the X2 but I am not sure what differences they will have, and problems I would encounter. What is everyones thoughts. Thanks. ~Jamie
