XFT carbon Trim systems (2)
Two144/148 XFT Carbon reduction Nozzle/trim ring and steer nozzle. Interchangeable I.D. rings for fixed and steer nozzle diameter. Trims farther angle than anything else ever made. Really neat parts just don’t have any use for small pumps anymore.
$400 each or both for $700
Yes, they bolt to any Yamaha 144/155 Reduction nozzle drilled/tapped horizontally for trim.
I would think you could use any single pull cable without the roller. I had them running with an XS cable and holder
I don’t know what else you have but obviously you need a lever and cable holder for the pump end and some way to secure the cable to the trim ring like a heim joint or oem ball and pivot.
