I have an XT handpole that I like to keep tight so it will not freely move up and down. It has 2 bolts on the inside, one of which is hard to get to when I tighten it to back it off against the other one. What I have been doing is tightening the one bolt all the way I want it then tightening the other bolt against it. Unfortunatly I dont see a way to get to the first bolt to back tighten it against then second bolt. I have used locktight Blue but that doesn't seem to work. I know that some people have drilled a hole thru the bolt then tighend the pole and placed a rod thru the bolt. Seems like an option. I am thinking maybe if I buy a 3rd bolt I can back tighten it that way? Locktight Red?
Open to options
Open to options
