SOLD Yamaha 781 engine
Yami-Rider
TigerCraft FV-PRO
Texoma
Sold
Selling a 781 flat top engine I got with a SJ I bought. Dont know the history on it or who built it. Will need rebuilt
The good
Cases are epoxy/ported/fly cut for big bore sleeves
Case threads are all good
Cylinder has big bore sleeves
Cylinder is fully ported/transfers/exhaust
R&D 85.5 pistons
The bad
Cylinder has 5 helicoil head bolts
3 Exhaust bolts holes will need to be time-certed
Crank rotates smoothly, but one of the small end connecting rod surfaces is rough, so crank will need rebuilt.
$350 shipped
20191225_213228-1152x864.jpg20191225_213217-1152x864.jpg20191225_211045-1152x864.jpg20191225_210212-1152x864.jpg20191225_200639-1152x864.jpg20191225_152833-1152x864.jpg20191225_152853-1152x864.jpg20191225_152902-1152x864.jpg
Yami-Rider
TigerCraft FV-PRO
Texoma
Purple holes need time certs, red hole has a bolt broke off 1/2" down in the hole
Top of cylinder was deck 4mm to work with flattop pistons only, will need to run flat top domes, ADA still makes them.
