Yamaha factory b pipe on sxi pro 750 1998 model
Hi guys I want to know if it would be possible to put a yamaha factory b pipe on sxi pro 750 1998 model? What other mods would I need to do in order to make it work or can I put in a full factory b pipe wet
problem is the waterbox on the 750sx/sxi is at the back of the engine compartment and the superjet chamber is setup for a nose mounted waterbox. anything is possible if you wanted to go through the trouble rerouting the exhaust.
I don't mind doing that, I can't find a sxi pro 750 factory exhaust and the b pipes are much easier to come across. What about if I use an sxr 800 exhaust, would that work and what would I have to do to get it work
I've had a speedwerx dry pipe out of an sxi pro before and it came with an aluminum pre bent tube that went arounf the nose of the ski and them a hose down the carb side. you just have to modify the tank foam to put the exh around the front. a b pipe should fit right in there with the use of any kawi 650 style 3 bolt manifold
