- Texas
I have the Driveshaft and Spline Lengths, but what are the Diameters for:
Wave Blaster 1 Driveshaft 62E-45511-00 Diameter= ?
SN 650 SuperJet Driveshaft 6R7-45511-01-00 Diameter= ?
Are they the same Diameter? Do Splines match?
Google Searched everywhere and No Joy. PwcToday was a dud.
Thinking about doing a Pump Setback on my Square Nose so it turns more like a 2008+ SJ.
Have a Spare 144 mm Impeller Housing that's 3 inches wide which would give it a 3" Setback.
The 650 SN Driveshaft is 26" long and the WB1 Driveshaft is 28-7/8".
This will work if the WB1 Driveshaft Diameter is the same as the 650 SJ Driveshaft.
Figured easiest/cheapest way is to install a 29" Driveshaft in the SN Pump since WB1 Pump Setups are hard to find.
Then all that I need to do is install All Thread long enough to join/clamp the longer Pump Assembly and epoxy-in some Pump Brass Inserts.
Plus a 3" Longer Steering Cable or Cable Extension...
