Permatex Moto Seal has served me well over the years so I stick with that, plus it's available almost everywhere that sells sealants for engines and it's not expensive. I have always installed crank seals with the springs out and this is how Yamaha recommends them to be as well. If you look at the seals to the right in the pic for a 650/701/760 crank, you'll see how the little shoulder is seated in the cases with the longer portion facing outward in the circled image of the seal cross section. You can also see the standoff squares on the seal pointing away from the crank. In your second pic those standoff squares are facing the camera. Also, I have never applied sealant to the rubber on crank seals or any rubber seal. Most sealants won't stick to rubber or won't stick to it for long. I have found it's best to just allow the rubber to seal against the cases as is but I do always add some waterproof grease to the inside diameter of the seals, it gives them some long lasting lubricant on an otherwise dry surface until they seat in and get oil from the fuel charge, it also helps them live a lot longer. They don't need a lot, just fill any voids and on the lip of the seal. That has always been adequate from my experience
