- central florida
Just one of the pictured f/w included. Flywheels are either lightened charging (heavy!), or light t/l from member zero, or t/l welded ring gear from member speedy sprocket. If you look at the pics on a large screen- you might notice new cables and rebuilt coil with 8.5 MSD carbon core wires- they don't fracture from vibration. Electric box and f/w cover are very low hours (paint is original). Bat. cables are marine grade. $890 shipped lower 48- If we're friends or relatives on PP- otherwise add pp fee. Detailed pics of f/w's can be had on request. This is just one of 3 sets available, however I would sell a " zero" lightened t/l f/w separately for $155 shipped CONUS. Note, pictured gaskets, spring and 2 washers for the Bendix, as well as rubber plug (discontinued by Yam) for crank case opening are included. Also included is a extension (ribbon) cable, if you later should wish to change the timing curve. Solenoid is new oem.
Optional is a programmer = $55. The pictured CPI switch is really water tight- not just rain proof= $100. You could mount the switch on your dash to switch between the 2 installed curves on the fly,
or extend the wires ( I don't furnish them) to use the optional for $40 h/pole switch housing.
