- Texas
To clarify:
OEM Lighting Coil (2 Green Wires) >Voltage Regulator/Rectifier>Battery
OEM Charging Coil( one Blue and one Brown Wire) >Zeeltronic
The OEM Charging Coil is the one that originally supplied Current for the Spark Plugs via CDI>IGNITION COIL>SPARK PLUGS
Now the Zeeltronic CDI is powered directly by the Battery.
What happens to the AC Current produced by the Charging Coil?
