Freakrider
X247
- Tampa Bay area
Does this work good on a blaster like it does on a SJ ? uppy_dog_eyes:
The blaster stop/start switch is the exact same as the SJ, so it would work the exact same.
Only difference, like was pointed out in the first responce, would be that the unguided missle would be larger in the case of the Blaster.
What's there to try about it? It's the same switch, same effect, and same risks involved.
My friends zip tie their SJ's for surf riding because the police do not go into big surf areas...anyone try it on their blaster ?
blasters will not circle i assume too
when u wreck ski keeps running and circles u for quick mount and go again...less use of starter/battery...no tug of lanyard on your wrist or vest when u are in the water near it but stretching it...feeling liberty from it !!What's the advantage of not using a lanyard?
Guys...that is my question...do blasters circle around (similar to SJ's) always so you can grab the side handle to get back on ? thx...
They should all circle, unless it's got quite a bit of throttle to straighten out the nozzle and the hull.
That said, just wrap the lanyard around the bars.
