How To: Shorten your stock pole -PICS-
D-Roc
I forgot!
The shorter you go the tighter you may need the pole. My pole is tight, i don't have to hold it up, it holds me. Something to think about trying if your pole is feeling to short.
I just finished the pole shortening, dirt simple, I'll let the crap setup tonight and slap everything back together tomorrow night. Took all of 3 1/2 hrs.
Cheers Ray
Tyler Zane
Open Your Eyes
Cheers Ray
Cool man, I think you will like it. I had wanted to shorten the pole on that sj for a while, just never got to it.
Its weird seeing my old Rn in your avatar... I guess i could change mine now lol
Thanks to the OP for the great write-up as well as the other suggestion in the thread. I shorted my pole -3" and fastened with SS button head cap screws/nylock nuts. After riding the ski I feel I have a lot more control in surf stance. I do however think that my foot holds might be a little too far back in my tray. When I'm locked into both of them the nose of the ski rides quite high.
perhaps an unsavvy Question: What needs to be done to the steering cable (if anything) after shortening the pole?
Very nice post, I am thinking of shortening my pole aswel, but I have the same question.
How difficult is it to reconnect de steering and throttle cable? Does this need a lot of tuning?
Someone answered it doesn't change anything, but I find that hard to believe (Sorry :) ) If someone can explain me?
Thanks
Thanks
Nothing youll have more of steering cable in engine bay, if anything youll have to re route it around motor
just a tip to clean out that base aluminum brack, i used a torch to light the fiber glass on fire. poop came right out with a chisel and was able to pull it all out smooth then clean it up with a chisel.
khaos
Party in a can!
Tidewater, VA
I did mine right on the ski.
You guys that are doing this with bolts are you running a long bolt all the eay through the pole? Like nut on bottom of pool, top of bolt on top? Or are you putting a nut in the middle of the foam? Not clear to me. Anyone have pics of how you did the bolts?
Started on mine. Old thread i know but have a question. The 2 vent hoses that go into the pole. One goes to gas tank, where doea the other go? Just down into hull is where i found it... awesome thread tho, was a lot of help. Just gotta go get glue and bolts and put it back together.
khaos
Party in a can!
Tidewater, VA
You prolly already dealt with this but one is to the gas tank and the other was to the stock battery vent.
