Use the water line that comes off the pipe, it's hotter than the one that comes off the head.
I guess the real variable here is that probably a lot of us all run our water differently. I run my water from my head to my pipe and then exit. Its much hotter after it leaves the pipe than the head
The other line comes out from the head to the top of the headpipe...
Sounds like you need to take the line out of the bottom of the headpipe and use that for your warmers. I'm assuming that line now goes out the side of the boat?
You could just pull it off of the bypass fitting and connect it to your line up the pole. That water would be toasty warm.
I switched from spray tubes to pressurizing the bars and drilling small holes in strategic places in the grips and it seems to be more effective and less trouble. I have a 1/8" pipe thread tapped into bars between bar clamps so it doesn't weaken the bars. It does require solid end caps on grips though.
It's only 57?.....Damn, toughin' up man....that's warm! Must be that FL blood![]()
