Want To Shorten Hull
I have a 97 RN and i want to shorten the back 3"
I was just looking at the hull and making some lines and measurments to cut but i cant seem to get the lines right.
I think i am over thinking it.
I want to angle cut it as well not straight cut.
Can somone chime in with some info on the proper lines to cut.
BrightE's
Paul
Seattle, WA
Def use a tape measure, then laser if you want perfect lines. It helps to have the cut be as flat as possible when you are putting a cap over the open hull hole to lay glass back onto.
Cut twice...measure once!
Make sure you have a beer or two in you as well.
Can't go wrong with that advice! I'm on that line of should I shorten my SN or not, have the try all cut out and defoamed so if it's ever going to happen it's now only thing I don't know what I would do is the exhaust tube.....
Thats where i am at not
tray is opened up and defoamed.
Out in colorado for work so i will see what i end up doing when i get back.
If i decide to takle it i will write up how i did it
WI
I cut 4 inches off and did it with the tray still intact. (not much fun but doable) If you already have it open, it's a no brainer. I'll probably never NOT shorten an SJ hull in the future while defoaming. Love the way it handles. Rips turns on a dime compared to stock IMO.
WI
I see your from MA... Where about? I'm in boston and we have a good group of guys that often ride out of hampton beach...
I live in Braintree,
just a small group of us that ride down the cape. Hoping to get some time in the surf this summer to improve my riding.
Would love to meet up with u guys im sure theres a lot i can learm
Does anyone else care to chime in on the pros and cons of a shortened SJ hull?
