daytona daytrip after daytona motorsurf. 2-11-06???
Status
Not open for further replies.
Wavedemon....the last few times I've been there, the shoal is high enough where you have a little beach right in the middle of the inlet except at high tide. As long as he can get to that, you two should have no problem swapping out right in front of the action.
thats true....its the same sandbar as you were learning to roll over...:biggthumpup:
primetime1267
AMSOIL Dealer
Well, I think it is just my headgasket.. I check the compression again today (cold) and it was right up at 180psi... But a strange thing occured though. A ******** load of gas came squirting out of the rear cylinder(small amounts out the front)...
Anyways, I am picking up the new gasket tomorrow from Action and right after I finish replacing my water pump on the Dodge, I will start working on the Blaster again..
If you are running dual carbs it sounds like you might have a leaking needle + seat in that back carb. I would pull it and see if it is worn.
-O
Status
